1990 Chrysler Imperial Repair Question
Topics covered: Brake pedal, Brakes, Abs.
Asked on June 16, 2009
1990 Chrysler Imperial retrofit from ABS to standard
Brakes problem
1990 Chrysler Imperial 6 cyl Front Wheel Drive Automatic 105000 miles
Car has the Bosch ABS system. I have already replaced rotors, pads, hydraulic control mod, relay and pump( mucho $$$ and hard to find)
Not going to mess with it anymore.
Want to convert to standard brakes, but need a different brake pedal.
What model and year brake pedal will fit the vacumn booster?
Or if I can find a decent print, I could modify the current pedal.
Answer
Replied on June 20, 2009
Dodge Dynastys are the same body style.
caradiodoc
