Mechanics
INSTALLING OIL PRESSURE SENDING UNIT
Chrysler Concorde
Hi.I have a 2000 Chrysler Concorde 2.7l with 72k miles on it. I've recently been seeing my oil pressure light flickering on and off. I checked the oil level and everything was fine. Had the oil pump pressure tested and it checked out fine. I was later told by a friend of mine, who is a mechanic, that it most likely is " your oil pressure sending unit". Is there any way to check out if it is indeed faulty, and if so, how would I replace it myself.
Thanks very much
DaveM
Demitch256
May 4, 2007.
It's either the sender or the circuit.A special shapped socket is needed to install and remove them.
Merlin2021
May 5, 2007.
AD
