The reasons for the check engine light on?
1998 ACURA CL
77,000 MILES • 4 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
What could be the reasons check engine light is on?
Oct 7, 2010 at 6:03 PM
2CP-ARCHIVES
  • 4,540 POSTS
The ECU (engine control unit) has detected a fault in the parameters of the engine management system; the light is a visual warning that a fault code has been set. Have the code read and report back or have your mechanic investigate the problem.
Oct 7, 2010 at 6:06 PM
