2000 Chrysler Concorde Repair Question
Topics covered: Engine, Catalytic converter, Ignition coil.
Asked on June 16, 2006
My car runs fine the first 15 - 20 min, then the engine stumbles while driving and eventually die, if you put it in neutral the engine will wildly accelerate, then will not crank until it cools. the catalytic converters will be glowing. also was scanned giving code p0356, ignition coil malfunction primary/secondary. i changed them. still having the same problem
