Mechanics
MASTER CYLINDER, OIL PAN, ABS MODULE
1994 Chrysler Concorde
Engine Mechanical problem
1994 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 134000 miles
I just wanted to know for my Concorde. What would be the labour time for replacing the master cylinder, the oil pan and the abs module on my Concorde. Would 3-4 hours sound about right?
I will probably have the MC/ABS module done at the shop. But, the oil pan I might do myself. The Haynes manual says the sway bar and trans mount should be removed to do the oil pan. My only concern is being in the rust belt area, do you think I'll have a lot of stubborn bolts? My experience with most suspension parts in this climate is that they are a major pain to remove because of corroded/seized fastners. But, I've never done front sway bar before or trans mount.
Thanks
Leon22
March 17, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
