1993 Chrysler Concorde Repair Question
Topics covered: Blower motor, Radio, Wiring.
Asked on July 5, 2007
A/c module wiring problem
I have a 1993 Concorde with automatic climate control. The previous owner attempted to install a radio in this car and damaged the wires going into the back of the ATC unit. The AC has not worked since. I picked up a wiring diagram for the unit and the wires were all messed up. I corrected them and the unit still does not work. The blower motor stays on all the time blowing hot air. I would like to know if there is a picture I can get from someone that shows the wire positions in the connector on the back of the ATC unit (the white connector with 6 wires). I want to make sure it is correct before I replace the module as I believe that the current unit is burned up. Thanks.
