Engine wont start
THEMAGICIAN
  • 2005 CHRYSLER 300
  • V8
  • 144,000 MILES
I have a 2005 Chrysler 300c with the hemi 5.7 it turns over but will not start it's getting fire to all 16 plugs and the gas is flowing. Changed the throttle body control because I can hold it open with my hand and the car starts. Can you help!
Wednesday, July 21st, 2010 AT 9:58 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
The first thing I would do is scan the computer for codes to see what comes up.
If no codes come up the next place I would go is the auto shut down relay.
Here is a guide and wiring diagrams so you can do some testing.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Tuesday, April 4th, 2017 AT 6:38 PM
MMORENO77901
  • 2005 CHRYSLER 300
  • V8
  • AWD
  • 71,000 MILES
I have 2005 chrysler 300c. It wont start. Everything works such as lights, radio, etc. Even tried jump starting still nothing. Does not make any noise when I turn key
Tuesday, April 4th, 2017 AT 6:39 PM (Merged)
If it's not a security issue see below:
**No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery condition and connections are good. Note:If it doesn't apply disregard.
MANUEL JOHNSON
  • 2005 CHRYSLER 300
  • 2.7L
  • 6 CYL
  • FWD
  • 100,000 MILES
Was driving on freeway and was accelerating and car just lost power. Now it wont turn over, like battery is dead and has a smell bad smell too it. Not a burning smell like bad gas.
Tuesday, April 4th, 2017 AT 6:40 PM (Merged)
FREEMBA
  • 1,152 POSTS
First thing, check the engine oil (correct as needed).
Try jump starting the car (just to see if it will turn over, this will help to see if the engine is locked up).
If your battery and starter are in good shape (or jump starting doesn't work) try using a socket and breaker bar on the center bolt of the crankshaft pulley) to turn the engine by hand [you should be able to turn the engine two revolutions in each direction] again this is done to check to see if the engine is locked up.
AMAZINGRICHY
  • 2005 CHRYSLER 300
  • 103 MILES
Dear Sir, I have a 2005 chrysler 300c Hemi and the AC Evaporator leaks gas, so the dash panel was removed in order to remove the evaporator and after the evaporator was replaced, the dash panel was reinstalled and when I tried to start the car it could not start, it turns and all the lights come up but it does not start nor crank. What will be the cause?
Go to this link: https://www.2carpros.com/articles/car-cranks-but-wont-start
BILL TROUTT
  • 6 POSTS
  • 2005 CHRYSLER 300
  • 136,000 MILES
Now all the lights come on the dash but there is no sign of the starter trying to engage or turn over. There is a buzz under the dash.
DOCFIXIT
  • 18,828 POSTS
Details did not post reply in message box
Sounds like a fuel problem
BILL TROUTT
  • 6 POSTS
But now all that happens is the engine lights come on on the dash and it makes not attempt to start. Will a fuel sensor cause this to happen? If so where do Iook?
Let me ask you-Is it cranking over and will not start or just won't do anything when you turn key to starting position?
BILL TROUTT
  • 6 POSTS
Wasn't doing anything. Tried another ingnition key and all is working fine now. Running and starting correctly.
RIVERMIKERAT
  • 6,110 POSTS
Thank you for letting us know. You need to get the other key reprogrammed.
GIZEL
  • 2005 CHRYSLER 300
  • V8
  • 50,000 MILES
Chrysler 300c 2005 don't start, no noise, I find the power outlet fuse out, I change it, but anyway the car don't start. Alarm, light, radio, seat motor and window motor are ok, but car don't start
  • 108,179 POSTS
Check to see if it has spark and fuel to the engine.
GABRIEL1976
  • 2005 CHRYSLER 300
  • 3.5L
  • V6
  • 198,700 MILES
Driving down the road then the rpm went high then car died and now it will not start and I have 9 codes p0016 p0113 p0222 p0223 p0344 p0340 p2111 p2172. I am thinking it is the throttle body.
  • 108,179 POSTS
If all these codes came on at once, I think it is something other than the throttle body. To me, it sounds like an electrical issue. Have you checked body grounds to make sure they are clean and tight? Also, make sure connections at the TB are clean and tight.
GABRIEL1976
How should I check all ground wires is there a way to do it?
KEN L
  • 42,883 POSTS
Hey GABRIEL,
Its also sounds like it could be the computer itself they had problems with those in that car, but you might what to check for a shorted injector which will do the same thing, here is a guide to help you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
The system ground all be at the intake manifold and the engine block near the starter.
Let me know what you find.
Best, Ken
