02 sensor location
2004 CHEVROLET VENTURE
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
VALENTINE48
Where is the bank 1 sensor 2 located on my van?
[img:7ee33d749e]http://www.2carpros.com/forum/automotive_pictures/171233_Norris_2004__Venture_1.jpg[/img:7ee33d749e]
Mar 21, 2008 at 11:34 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
Here is a guide to help you replace the oxygen sensor once you find it from the diagrams below:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Cheers
Mar 22, 2008 at 7:09 AM
SAM JACOBS
Oxygen sensor where is it? I cannot find it oxygen sensor.
Aug 17, 2018 at 7:08 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello, Here is the information you requested. I gave you two pictures. One with red arrows and one without. Looks like you have two sensors. Have a great day!
https://images.2carpros.com/forum/automotive_pictures/248015_1_147.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_2_96.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_3_66.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_4_42.jpg
IMPALASS
  • 3,112 POSTS
Hello.
One other thing.
Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you. Several seem pretty major. The fuel tank, ball joint, airbag. So for your safety you might just give them a call to make sure your vehicle is okay.
08089
06/13/2008
Campaign - Analog OnStar(R) Deactivation
07203A
02/15/2008
Campaign - Fuel Tank Inlet Check Valve Fracturing
02019
05/01/2002
Campaign - Brake Booster Inspection/Replacement
01070
11/01/2001
Campaign - ABS Electronic Control Module Replacement
06230
11/27/2007
Recall - Fuel Tank Replacement
NHTSA07V349000
08/07/2007
Recall 07V349000: Fuel Tank Replacement
06089
09/28/2006
Recall - Rear Suspension Ball Joint Separation (Canada)
04110
05/24/2005
Recall - Power Sliding Door Interior Handle Replacement
NHTSA04V597000
12/21/2004
Recall 04V597000: Power Sliding Door Interior Handle
02032
08/01/2002
Recall - Driver Air Bag Inspection/Replacement
NHTSA02V222000
08/01/2002
Recall 02V222000: Driver's Air Bag Replacement
TOOMOO4U
Van LT model.
FWD
3.4L V6
65,000 miles.
Error code:
P0135 Bank 1 Sensor 1 Heater Circuit
This is an oxygen sensor that resides upstream from the catalytic converter.
I have been told that there are two O2 sensors upstream on this minivan.
The one of them that I can find resides just to the passenger side of the point where the two exhaust pipes (manifold?) come together under and just behind the engine.
If there really is another upstream sensor, where is it and which one would I replace?
(Chevrolet garage had to remove and replace the intake manifold gasket and seal at 41,500 miles)
ROCKWOOD84
  • 103 POSTS
You have one before catalytic converter [bank one] another one behind catalytic converter [ bank two]. The bank one is more expensive than bank two.
