Mechanics
CHEVROLET VENTURE BATTERY PROBLEM
2001 Chevrolet Venture
I WAS USING THE VEHICLE TWICE THE SAME DAY AND THE IT WOULD NOT START. WHEN I TRIED TO START IT THE LIGHTS DIMMED AND NO RADIO ETC. TRIED TO JUMP START BUT THERE WAS NOT EVEN A GLIMMER FROM THE INSIDE LIGHTS ETC. AFTER ABOUT 5 MINUTES WHEN I TURNED ON THE IGNITION AND TRIED TO START IT THE ONLY THING THAT CAME ONEWAS THE CHECK ENGINE LIGHT AND NOW NOT EVEN THAT.
Mcpljim
August 28, 2007.
I assume this is a 3.4 motor?
While this may not be the case, it needs to be mentioned. The intake gaskets can go on an instant and fill the cylinders causing a hydrolock. Since the starter can't overcome the fluid compression, it will dim the lights and not crank. I can bend the crank shaft by trying. Before getting too far with this, check the oil and coolant for a level or odd color to it. If anything abnormal there then we need to continue down that path.
Having said that, how old is the battery? Sometimes a jump won't take from a lousy connection with the cables or maybe you have a loose battery cable. Check and get back.
AD
