1980 Chevy Van battery leaking
1980 CHEVROLET VAN
79,000 MILES • V8 • 2WD • AUTOMATIC
COURIERELBIE
Hello I have a 1980 chevy motor home class c van front end. when I park it battery acid leaks out and is causing corrosion. My question is what is the regular voltage for something like that? when off, and when idleing? I checked and when off it was 13 to 14. When running it jumped to 28-30. I run a power converter but I dont think thats causing the problem its only a 400 watt converter Is my alternator over charging? thank you
Jul 10, 2010 at 9:53 AM
