SMOKE!!!
CHEVROLET TRUCK
CHEVYTRUCKER
I have a 1986 Chevy c10 1/2 ton 4wd with a 350 small block v8. i recently have redone the valvecover and manifold gaskets, new spark plugs and wires and an oil change. my question is that when i let my truck idle, it seems to be ok, but when i dive it, it smokes alot, and i meen alot! it seems to be coming from the motor and the exaust, what is wrong with my truck? help please!
Oct 2, 2007 at 10:18 PM
  • CAR REPAIR CONTRIBUTOR
What is the color of the smoke?
Oct 2, 2007 at 10:28 PM
CHEVYTRUCKER
the smoke is a white to a greyish color. it might have had alittle of blue but im not sure. i dont recall 4sure seeing any blue at all.
Oct 2, 2007 at 10:33 PM
Check the PCV valve. The engine temperature is it getting hotter than usual?
Have some one start it up and raise the rpm to 2500- look at the engine. Probably its still leaking oil and dropping on the exhaust manifold-look behind the distributor and front of the intake-
Something tells me that the rubber gasket slip off or the end to it is not sealedwhen re-installing the intake manifold
Try retorquing it down follow the correct pattern and ft lbs.
Oct 3, 2007 at 2:19 AM
CHEVYTRUCKER
ok i have done that and it still smokes really bad, like i had done nothing. and it does leak oil really bad all over the driver side of the moter on behind the motor on the passenger side of the truck.
Oct 3, 2007 at 11:17 AM
Check the oil pressure sending unit its right beside the distributor and recheck the valve cover gasket.
That's the only plact it will leak oil from unless you your rear seal is gone. Gotta look at it good.
Oct 3, 2007 at 3:01 PM
CHEVYTRUCKER
i just want to say thanks, you guys are running one heck of a site here and your help was much appreciated. i got it fixed now so i just want to tell you how thankful i am! thanks again from the Chevy Trucker!!!! i know where i will com again if i ever need help. thanks again guys!
Oct 3, 2007 at 8:17 PM
