1998 Chevrolet Truck Repair Question
Topics covered: Engine, Check engine light, Compression.
Asked on April 6, 2008
1998 Chevy Truck
Mulitple misfires- replaced plugs, wires, cap, rotor, injectors, timing
Under light load miss with mulitple cylinder misfires
check engine light does not come on, with scanner hooked up, shows 2 or 3 cylinders misfiring
fuel pressure check- ok, injector balance check-ok, EGR - ok
Any Ideas?
Answer
Replied on April 10, 2008
Which cylinders are missing? The pressure regulator is on the passenger side (cyl 2 4 6 8 ) and if blown will leak raw fuel into the engine. What parts did you use in the tune up? Just because the balance test came out ok doesnt mean the injectors are spraying a good patter or the exact same amount. HAs a compression test and leak down test been done to verify the engine is solid and doesnt have a leaking intake valve or two
