Mechanics
CHEVY CRANKS BUT NO START
2006 Chevrolet Trailblazer
Engine Mechanical problem
2006 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic 57000 miles
i recently replaced the fuel level sensor on my 06 trailblazer. I dropped the tank removed fuel pump assembly repaired the level sensor and reinstalled in in revearse order of take down. I primed the pump and the vehical started and idled fine. Went for a test drive and rpms dropped to 5k and began to idle very rough. I checked fuel psi, the gauge read 59 psi, it should read specs are 57 psi. Looked for losse connections, no leaks all plugs and hoses are secure. I attemped to start and again very rough idle. Checked codes po506 low idle indication. Replaced plugs cleaned throttle body, and now still will not start please help.
Torri09
January 6, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
