2CarPros - Car Questions & Answers
2000 Chevrolet Tracker Repair Question
Topics covered: Fuse, Four wheel drive, Turn signals.
Asked on July 21, 2009
2000 Chevy Tracker turn signal fuses
Electrical problem
2000 Chevy Tracker 4 cyl Four Wheel Drive Manual 128000 miles
Turn signals blow fuse (under dash) when turn signal engaged. Seems to happen after I put gear shift into reverse. 4-way flashers (same bulb) continue to work OK. I've changed all bulbs too.
Avatar Asked by tmason123
Answer
Replied on April 22, 2010
if signal fuse blows after using switch then most likely a faulty signal switch is the cause.
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
