Mechanics
CHEVY ROUGH IDLE WHEN IN ANY GEAR
1999 Chevrolet Tracker
Engine Performance problem
1999 Chevy Tracker 4 cyl Two Wheel Drive Automatic
THis tracker has 123K miles. My son had the car and says that it has always had a severely rough idle when in gear. The rpms drop quickly immediately after it is put in gear but comes back up to 700-900 ropm. Just seems like it is loading up more than it should compared to other 4 cyl automatics. It also idles rough but not quite as bad when in neutral or park and the A/C is turned on. It runs smooth when rpm's brought up to 12-1500.
I plan on changing the trany filter and try to check the egr valve to see if it is sticking. I cannot find much info on that egr.
Any other thoughts?
Webairron
June 23, 2009.
Try cleaning out the idle air control valve and the EGR and PCV valves.
Rasmataz
Jun 23, 2009.
AD
