Yesterday monring the battery in my 2004 Tahoe was dead. After replacing the battery, the motor idled a little bit rough for a few seconds, but then normalized. However, my air conditioning will now only blow out of the defrost vents. This is the case regardless of whether the system is set on "auto" or whether you manually select the vents (i.e. dash vents, floor vents, defrost, etc). Prior to the battery going dead, I had no problems with the AC. Just because of the timing, I assume the dead battery and this AC problem are somehow connected. Can you offer any advice on possible causes and solutions?
Aug 19, 2019 at 6:39 PM
(Merged)
