Mechanics
CHEVY STARTING PROBLEMS
2005 Chevrolet Tahoe
Electrical problem
2005 Chevy Tahoe V8 All Wheel Drive Automatic 50000 miles
My 2005 tahoe starts fine, the first time of the day, but if I drive for 15-20 minutes turn it off than try to restart, it will not crank, no noise no sound whatsoever. If I keep turning the key back and fourth it will eventually crank and start. Any suggestions.
Tschraer1
March 24, 2009.
Hello, I'd have to do the basic tests on the wiring circuits. You might make sure the battery cables/wires are clean and tight on both ends.
My next step would be to check the wiring circuits at the starter relay, when it refuses to crank. The problem could be the feed to or from the ignition switch. I'd have to track the circuit.
JDL
Mar 24, 2009.
AD
