1999 Chevrolet Tahoe Repair Question
Topics covered: Ignition switch, Smoke, Coolant.
Asked on September 4, 2007
1999 chevy tahoe ignition switch problems
I have a 1999 tahoe 4x4 5.7l with 214000 miles. i keep having to replace the ignition switch due to starting problems.it starts missing and running bad, then suddenly won't start. when i crank it it won't try to fire untill i let off the key. the next day it will start and smoke oil smoke for a minute but still misses and runs bad. if i replace the ignition switch it will start and run fine everytime for about two weeks and then then problem starts again. the ignition cures it everytime for about two weeks but is too expensive and takes too much time replacing it . what is the problem, what is the cure, and how do i get g.m. to pay for it or cure it perm.? never any oil smoke after replacing the ign. switch.
Answer
Replied on June 10, 2010
Mine has been doing this for a while.. but it seems to blow steam.. meaning that it is burning coolant and not oil.. I am wondering if when i replace the ignition switch if that will fix the trouble..
