Flashers not working properly
LACAJUN
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 134,000 MILES
Installed LED flashers in rear, no problem. Installed LED flashers in front and right flasher settled in, left flasher had a problem. With lights "off" left flasher will flash but so does the display lighting and the radio lighting. With lights in the "on" position left arrow appears on display, does not flash. I have changed the flasher relay, GM11516051with newer relay designed to work with LED's. Did not fix the problem.
Saturday, November 19th, 2016 AT 4:56 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,884 POSTS
Hey LACajun,
One of two things is happening, either you got the wires mixed up or the resistance in the LED kit will not work with the BCM of the vehicle.
I would recheck the wires and then if that does work put back the stock lights to see if that works.
Please let us know happens so it will help others.
Best, Ken
Tuesday, November 22nd, 2016 AT 8:09 PM
LESTAHOE
  • 1996 CHEVROLET TAHOE
Where is the turn signal flasher located?
Sunday, May 17th, 2020 AT 11:02 AM (Merged)
Turn/Hazard Flasher-see location below:
Convenience Center
https://www.2carpros.com/forum/automotive_pictures/12900_t_32.jpg
