2001 Chevrolet Suburban Repair Question
Asked on June 16, 2009
Chevy low coolant
Engine Cooling problem
2001 Chevy Suburban V8 Two Wheel Drive Automatic 117000 miles
We've been having this problem for 2 years now. Low coolant light comes on & resevoir is usually about 1 inch low on fluid. We had the reservoir replaced because the mechanic thought the sensor was bad. Now the vehicle is leaving a small puddle of coolant on the ground. Coolant light comes on & again reservoir is only slightly low. We've been adding coolant about once a month. Took it to another mechanic & they have no clue. Is this the water pump going bad for 2 years now?
