P0451 code?
FRANKIE MICHAEL
  • 2014 CHEVROLET SILVERADO
  • 6 CYL
  • 68,000 MILES
I bought my truck two months ago at a Toyota dealership. Check engine light came on went to the dealership they said they did not have the right equipment to check it, so I went to AutoZone they ran the code it was P0451. Then went to the Chevrolet dealership they told me it would be about a $600.00 fix. But that I should not worry about it it is not going to hurt anything. My question is, should I be more concerned about this? I had them clear the light but it came back on a few days later.
Do you
have the same problem?
Monday, June 25th, 2018 AT 8:29 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Sounds like your showing a PCM code for EVAP system/fuel pressure sensor issue. This system is in place to capture unburned gasses from engine/fuel system to be sent back through system to be reburned and not to be released into atmosphere. Smog laws in certain states are tough on this so when come time for a Smog Check (depending on state) it would not allow testing until Check Engine light is off/problem fixed. This could be as simple as a defective gas cap/gas cap seal. Shops can do a smoke test to see if/where a leak is coming from. Here are some hints:
Loose or missing fuel cap.
Clogged fuel tank pressure relief valve.
Broken, collapsed, or burned EVAP hoses/lines.
Cracked or broken charcoal canister.
Monday, June 25th, 2018 AT 9:08 PM
HARRY P
  • 2,293 POSTS
Checking your Evap system: https://www.2carpros.com/articles/evap-system-code-repair
Many times, a loose gas cap or leaking cap seal can cause EVAP system codes to set. I always start with taking a look at the cap seal. Take the cap off, turn it over, and look at the rubber ring seal. If it has cracks in it, then replace the cap. You can get a new one at AutoZone for about $10.00.
Tuesday, June 26th, 2018 AT 4:14 AM
REELPRO
  • 2006 CHEVROLET SILVERADO
  • V8
  • 60,000 MILES
What causes this error code, and how do I fix it. P0451?
Saturday, September 19th, 2020 AT 2:21 PM (Merged)
SCOTTY DEE
  • 592 POSTS
This video will show you how to fix it P0454 which is similar
https://youtu.be/iH92vcUWJzs
DTC P0451
SYSTEM DESCRIPTION
The fuel tank pressure (FTP) sensor measures air pressure or vacuum in the evaporative emission (EVAP) system. The control module supplies a 5-volt reference and a low reference circuit to the FTP sensor. The FTP sensor signal voltage varies, depending on EVAP system pressure or vacuum. The controller uses this FTP signal to determine atmospheric pressure for use in the engine-off small leak test, P0442. Before using this signal as an atmospheric reference, it must first be re-zeroed. If the FTP signal is out of range during the re-zero procedure, this DTC will set.
DTC DESCRIPTOR
This diagnostic procedure supports the following DTC:
DTC P0451 Fuel Tank Pressure (FTP) Sensor Performance
CONDITIONS FOR RUNNING THE DTC
DTC P0451 runs only when the engine-off natural vacuum small leak test, DTC P0442, executes.
The number of times this test runs can range from 0-2 per engine-off period. The length of the test can be up to 40 minutes .
CONDITIONS FOR SETTING THE DTC
This DTC will set if the controller is unable to re-zero the FTP sensor voltage within a calibrated range during the engine-off small leak test, P0442.
ACTION TAKEN WHEN THE DTC SETS
The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The control module turns OFF the MIL after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and DTC with a scan tool.
DIAGNOSTIC AIDS
A restriction in the EVAP canister or vent lines could prevent fuel vapor pressure from bleeding off fast enough. If the vent system cannot bleed off pressure fast enough, this code can set. When pressure is applied to the system and released, a properly operating system will return to the atmospheric pressure rapidly. By using a scan tool and the J 41413-200 Evaporative Emission System Tester (EEST), pressure can be applied to the system, then released, while monitoring the FTP sensor parameter to see that pressure can be released within 30 seconds .
An FTP sensor that is skewed or does not have a linear transition from low to high may cause this code to set. Scan tool output controls, snapshot, and plot functions can help detect erratic sensor response. To test the sensor signal under vacuum conditions, use the Quick Snapshot and the Purge/Seal functions to capture data while commanding purge to 20 percent , then plot the data to look for erratic sensor operation. A similar test can be done for the pressure side of the sensor operation by applying pressure with the J 41413-200 while taking a snapshot.
A full fuel tank may cause misdiagnosis.
When using the electronic emission system tester (EEST) to apply pressure, you can regulate the amount of pressure by activating the remote switch ON and OFF while observing pressure in the EVAP system using a scan tool.
TEST DESCRIPTION
