Mechanics
CHEVY FIREING
2005 Chevrolet Silverado
Electrical problem
2005 Chevy Silverado 6 cyl Two Wheel Drive Automatic 88000 miles
does not fire, Installed new coil & icm
Hollon
July 17, 2010.
Hi Hollon, Welcome to 2carpros and TY for the donation
Do below to determine if its a fuel or spark problem and comeback with some testing results we start here.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Rasmataz
Jul 17, 2010.
I get fire through coil but not to plugs
Hollon
Jul 19, 2010.
Inspect dizzy cap and ignition rotor
AD
Rasmataz
Jul 19, 2010.
AD
