About 200 miles later, this evening, a horrible clunking noise developed from the rear of the truck.
It appeared to be rotational in nature. I looked under the truck and found axle lubricant on the inside of the passenger inner rear wheel(it is a dually) as well as metal shavings. Also, there was a bit if smoke. My initial assessment is an axle bearing.
My question relates to the brake replacement that was performed about 2 weeks ago. I am not sure of what all is involved with the brake replacement. Is there any possibility that "something" could have been disturbed that contributed to the issue I currently have?
Thanks,
Ed
SPONSORED LINKS
have the same problem?
Sunday, May 3rd, 2009 AT 11:59 PM
