Mechanics
CHEVY TRUCK WILL NOT START
2002 Chevrolet Silverado
Engine Mechanical problem
2002 Chevy Silverado V8 Four Wheel Drive Automatic 107000 miles
MY TRUCK HAS BEEN RUNNING FINE, BUT GOT TO START IT UP AND IT DID NOT START. LIGHTS WORK, AND ALL THE WORKS FINE, JUST WILL NOT START?
R WALL
April 17, 2008.
Your coil could be bad. There are two wires coming from your distributer to another peice mounted to the intake. An easy way to check this is to take out the number 1 spark plug, this is the one located on the driverside closest to the front of the truck. Plug the spark plug into the plug wire and ground the plug to the block. Then have somone turn the starter so you can see if it sparks. If it does this is not your problem and you may want to check the fuel pump.
Handyrandy1027
Apr 26, 2008.
AD
