Mechanics
CHEVY INTERIOR DOOR PANEL REMOVAL
2002 Chevrolet Silverado
Interior problem
2002 Chevy Silverado V8 Four Wheel Drive Automatic
Need to remove interior door panel to check why window is not working. Is there a tool I need to remove the panel?
Jamntam
December 12, 2009.
I would guess that the '02 is the same as a 2000. With that said, there are two screws that must be removed. One is on the door skin at the interior door grab handle. The second one is under the power lock/window panel on the door skin (you have to remove the panel. Should just pull off). Then you have to pop off the small tri-angular trim piece at the top/front of the door skin (by the bottom front of your window). Then the door skin just lifts straight up and out (you may have wires attached to the back of the door skin for speakers and courtesy lights if so equipt). The only tool you need is an 8mm socket to remove the two screws.
Quagmire86
Dec 12, 2009.
AD
