Mechanics
CHEVY WILL NOT START
2001 Chevrolet Silverado
Engine Mechanical problem
2001 Chevy Silverado V8 Two Wheel Drive Automatic 70,000 miles
The truck shut down while driving, will not retart, starter turns, no engine turn over, code test passes, fuel filter under the truck bed allow fuel to pass through.
Is there a second fuel filter?
I take it you mean that the engine turns over just won't start.
When you turn the key to the On Position do you hear the fuel pump run for about 3 - 5 seconds?
If Not check fuel pump relay. If relay appears good check out the link below for testing fuel pressure and regulator.
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Also check to see if you have spark at the plugs. Spark should be Bright Bluish/White.
Obxautomedic
Aug 8, 2009.
