Security light on why?
KELLI HICKS
  • 2006 CHEVROLET SILVERADO
  • 4WD
  • 12,900 MILES
So, I bought this truck and changed the motor. Truck runs like a dream, absolutely perfect for a day and a half. I turn the truck off and it never starts again. The security light stays on solid, not flashing! I've tried the relearn process several times and i'm at the point that I'm ready to burn this truck to the ground! I'm about to pull my hair out. Someone help please!
Do you
have the same problem?
Wednesday, November 4th, 2020 AT 6:40 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
How about trying our sites anti-theft, security system reset. Here is the tutorial:
https://www.2carpros.com/articles/how-to-reset-a-security-system
After reading just scroll the page to find Chevrolet. Let us know what happens and we'll go from there. Hope this helps and thanks for using 2CarPros.
Monday, January 25th, 2021 AT 12:33 PM
KELLI HICKS
We tried these things. Nothing has worked.
DANNY L
  • 5,648 POSTS
Hello again.
I understand that dealing with a persistent issue like this can be frustrating. The solid security light on your 2006 Chevrolet Silverado typically indicates a problem with the vehicle's anti-theft system. Here are a few suggestions to help address the issue:
Check the key: Ensure that you are using the original key that matches the new engine's computer. If you are using a different key or a key that has not been programmed to the vehicle, the security system may not recognize it and prevent the engine from starting.
Battery and connections: Check the battery and its connections to ensure they are in good condition. A weak or faulty battery, as well as loose or corroded connections, can sometimes trigger security system issues. Make sure the battery is fully charged and the terminals are clean and tight.
Attempt the relearn process: Since you mentioned that you have already tried the relearn process multiple times, it's possible that there is an underlying issue causing it to fail. However, it's worth attempting the process again following the specific steps outlined in your vehicle's manual or contacting a Chevrolet dealership for guidance.
Passlock sensor and wiring: The Passlock sensor is part of the vehicle's anti-theft system and can occasionally cause issues. Inspect the wiring and connections associated with the Passlock sensor for any damage, loose connections, or corrosion. If any issues are found, they may need to be repaired or replaced.
Danny-
SOUTHERNREBS59
  • 2005 CHEVROLET SILVERADO
  • V8
  • 280,000 MILES
A couple of months ago our truck quit running we replaced the crankshaft sensor and it ran fine for a few months. Now we are having the same problems and our security light is coming on. What do we need to do.
Friday, April 23rd, 2021 AT 12:08 PM (Merged)
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you have a spare key try it. If not try cleaning off that key where the pellet is and try again. I would do a hard system reboot, remove the negative battery cable and hold it to the positive post for 1 minute then reconnect. This will discharge all capacitors so the system can come back online. This guide can help as well.
JEROMECHARLES
  • 2002 CHEVROLET SILVERADO
  • 110,000 MILES
Sometimes I try to start my truck and it will not crank, during this time the security light comes on and stays on. I have to wait a good ten to fifteen minutes before the security light goes out and the truck to start.
DRCRANKNWRENCH
  • 3,380 POSTS
There is an error in the security system module.
Get it checked for trouble codes and come back if you need them translated.
WOLFENPIXELS
  • 14 POSTS
Bad theft module or wrong key my friend. :)
ROBERT68
  • 6 CYL
  • 95,000 MILES
Truck wont start and sercurity lights comes on and wont go off key isnt in ignition
Friday, April 23rd, 2021 AT 12:09 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
turn key "off" and wait 5 seconds
repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
ENRIQUEDELEON6
  • 5.3L
  • V8
  • 350,000 MILES
I replaced the ABS on my truck but now it doesn't start and a security light appears on the information.
Friday, April 23rd, 2021 AT 12:10 PM (Merged)
  • 52,797 POSTS
Good afternoon,
It sounds like the key has forgotten the password.
I assume you removed the battery cable. This is common when the cable is removed. I posted the re learn procedure below.
PROGRAMMING REPLACEMENT PASSLOCK(TM) SENSOR, BCM, OR PCM
IMPORTANT:
The body control module (BCM) must be programmed with the proper RPO configurations before performing learn procedures. See Body Control Module (BCM) Programming/RPO Configuration.
If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn PASSLOCK(TM) sensor data code immediately. The existing PCM however, must learn the new fuel continue password when the BCM is replaced.
If replacing a PCM with a GM Service Parts Operations (SPO) replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password and will require a learn procedure after programming to learn the current vehicle's password.
CONDITIONS
Use this procedure after replacing:
Passlock(TM) Sensor
BCM
PCM
LEARN PROCEDURES
There are two available methods to perform the programming procedure:
A 10 minutes procedure which requires a Tech 2 and a techline terminal.
A 30 minutes procedure which does not require the use of any tools.
10 Minute Learn Procedure
TOOLS REQUIRED
Tech 2
Techline terminal with current Service Programming System (SPS) software
1. Connect the Tech 2 to the vehicle.
2. Select "Request Information" under "Service Programming".
3. Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
4. On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
5. Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
6. Turn ON the ignition, with the engine OFF.
7. Select "VTD Re-Learn" under "Service Programming".
8. Attempt to start the engine, then release the key to ON, vehicle will not start.
9. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF, the vehicle is now ready to relearn the PASSLOCK(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
10. Turn OFF the ignition, and wait 5 seconds.
11. Start the engine, the vehicle has now learned the password.
12. With the Tech 2 scan tool, clear any DTCs.
30 Minute Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON, vehicle will not start.
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready to relearn the PASSLOCK(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learns the PASSLOCK(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the PASSLOCK(TM) Sensor Data Code and/or password.
7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
KYLE WROBLESKI
  • V8
  • 142,000 MILES
I had a wire burn out which controlled my low beams. The wire was burnt and disconnected from the terminal. This is right behind my steering wheel. I took the white block off which the terminals where placed in replaced the severed terminals placed them back in th block and put the block back on to the copper prongs. I put my key in the ignition and a security light appeared in my message box. My truck will not start and I dont know what to do can you help me?
Wednesday, May 5th, 2021 AT 9:40 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
I do not understand what you are saying "it will stay cranked"? Does it start, run then shut off? The security will shut down the fuel pump. Try this to see if it will relearn the key:
1- Turn key to 'run" position, try to start and let key return to "on" position.
2-After approximately ten minutes the security light should turn off.
3-Turn ignition to "off" position and wait five seconds.
4-Repeat steps 1-4 two more times for a total of three cycles equaling thirty minutes.
5- Start engine.
KYLE WROBLESKI
Steps worked!
KCPEESTOL
  • 2001 CHEVROLET SILVERADO
  • V8
  • 113,500 MILES
The security light comes on occasionally and stays on. Also, the truck will not start occasionally. It turns over like it wants to start but does not. I eventually get it started. The fuel pump has been replaced twice now. What could be wrong with it?
BMRFIXIT
  • 19,053 POSTS
These trucks had problem with the BCM which is the car alarm. Here is the location so you can replace it, but you will need to have it programmed to the truck before it will run. The cost is about $130.00.
On the lower left side of the I/P below the steering column.
Cheers
LIZ8907
Nice! I did what you said and then had my truck towed free from AAA to the shop and now all fixed! I love this site :) Cost me $80.00 but I know the guy.
PETERT1943
  • 2000 CHEVROLET SILVERADO
  • V8
  • 50,000 MILES
Security Light Stays on & Headlights will not work.
Wednesday, May 5th, 2021 AT 9:41 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Have you done a relearn on the pass-key?
Gm pass lock relearn- Ignition to "run" position, try to start and let key return to "run" position.
Approximately ten minutes security light will go off.
Turn key "off" and wait five seconds.
Repeat two more times for a total of three relearns.
Turn key off, then start it.
