Mechanics
CHEVY ENGINE OVERHEATING
2000 Chevrolet Silverado
Engine Cooling problem
2000 Chevy Silverado V8 Four Wheel Drive Automatic
My buddy has a 2000 chevy silverado 1500 z71, last week it started to overheat, so we went through some steps and put a new thermostat on it it's cooled down alot but when he turns the air conditioning the engine temp starts going up again, what might be other options to check to see what is causing this thank you.
AD
Poynter15
June 14, 2010.
Not much info here (mileage, maintenance performed, how it's driven, etc.) Could be water pump, radiator, cooling fans not working, low or worn out oil (remember, oil doesn't just work as a lubricant, it works as a cooler as well).
02redcamaro
Jun 20, 2010.
AD
