1997 Chevrolet Silverado
Other Category problem
1997 Chevy Silverado V8 Four Wheel Drive Automatic 137000 miles
when I am at low speed (under abs speed) in 4x4 and brake in klunks? If I back up if feels like the front end going to fall out? Will not do it on dry hard surface or near as bad in 2wd. Fyi rebuild ball joint, tie rods, inner & outers, idler asmbl, pitmen arm. And had it alined, new shocks. Just service 4l60e trans, wheel bearings and rotors, pads. I did find a bad u joint in the rear drive shaft front joint. Checked calipers monting and caliper bolts. Is this ok or do I have a drive train issue. I also put 305 m/t goodrich tires on I had to turn up the torsion bars? Could this be a issue. Thanx so much
February 10, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
