2CarPros - Car Questions & Answers
1997 Chevrolet Silverado Repair Question
Topics covered: Engine, Body, Four wheel drive.
Asked on October 25, 2008
1997 Chevy Silverado FUEL SYSTEM
Engine Mechanical problem
1997 Chevy Silverado V8 Four Wheel Drive Automatic 150000 miles
truck is not starting, already checked fuel pump and fuel relay, still won't start...could you send me a diagram of the fuel system please and direct me of what else to check to get the truck back running, thanks.
Avatar Asked by Boston01
Answer
Replied on October 25, 2008
before i do that, are you sure its the fuel system?
have you tested ignition and fuel system?
you tried spraying starting fluid down the throttle body and cranking it? does it fire up then die? fire up and stay running?
Tiny Answered by blackop555 (expert)
10,902 answers provided
yes I've tried that, truck runs while feeding fuel. Seems as if the gas isn't getting to the injecter but has fuel at the fuel rail. Not showing any engine code.
Tiny Response from Boston01
1 question asked
whats the fuel pressure at the rail, dont just push on it and if fuel comes out think its good, you need to know how much pressure.
if pressure is within specs i would be checkign pulse from the fuel injectors.
