Mechanics
CHEVY TRANSMISSION FLUID LEAKING FROM FRONT
1996 Chevrolet Silverado
Transmission problem
1996 Chevy Silverado V8 Two Wheel Drive Automatic 210000 miles
There is transmission fluid leaking from around one of the bearings of the U Joint on the front of the driveshaft. The shaft around the yoke is dry! It looks as if the fluid is coming from the bearing itself. Is the Yoke hollow or does it have splines going to the bearing for lubrication?
SgtTurnkey26
February 13, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
