fuel filter location and replacement?
1999 CHEVROLET SILVERADO
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIGER6060
location of fuel filter I need to change it out to save some money.
Feb 27, 2010 at 2:46 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Under vehicle, driver side, below seating area, near fuel tank, mounted on frame rail in fuel line. This guide should help with instructions in the diagrams below to show you how on your truck.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
May 23, 2019 at 5:36 PM
SNELL KING
Need to know how to reduce the pressure before I change the inline fuel filter, and how to change the fuel filter
Sep 10, 2020 at 12:24 PM (Merged)
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_97_fuel_filter_1.jpg
driverside frame rail, Threaded fitting on both ends, need a couple of wrenches. As far as pressure, after the vehicle sits overnight without the key being cycled or engine started, there usually isn't much pressure. A fuel pressure gage has a bleedoff valve on it, bleed into a container, or make sure the pump is disconnected, start the the vehicle, when it dies the pressure should be gone. That doesn't mean gas won't drain from the lines, take gas cap off. Sometimes I'll plug the gas lines with something till ready to go back with new filter. If you use a droplite don't lay it where gas might drip on it.
SWEETPEA55
where is the fuel filter located on a 3500 diesel truck
1996 Chevy Truck K 3500 Truck 4WD V8-6.5L DSL Turbo VIN F Fuel Filter Part 1
https://images.2carpros.com/forum/automotive_pictures/12900_ffc1_1.gif
Fuel Filter Part 2
https://images.2carpros.com/forum/automotive_pictures/12900_ffc2_1.gif
Fuel Filter Part 3
https://images.2carpros.com/forum/automotive_pictures/12900_ffc3_1.gif
The fuel filter is attached to the front of the intake manifold between the first two runners.
JONES2278
Hi. My truck will not start because i believe my fuel filter is clogged. Is there a way to start it so i can get it somewhere to get a new filter? Thanks
Sep 10, 2020 at 12:31 PM (Merged)
PEAR69
  • 1,482 POSTS
I suppose you can cut the fuel lines and bypass the fuel filter, but by that time you could have just changed the fuel filter. If you are getting no fuel to the injecters and the fuel filter is blocked bad enough to not start the engine, then have your fuel pump properly tested for any weakness -- both pressure wise and electricaly. Many mechanics have no clue about how to test for the electrical strength of a fuel pump, so take it to an ASE certified mechanic.
JOHNSKLENAR
I just recently replace the spark plugs on my 300,000 mile chevy,Looks brand new,and I want to replace my fuel filter,but having troulble getting it out,don't want to strip the threads on it, help please
Sep 10, 2020 at 12:32 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
It's a pretty straight forward job. If the threads are rusted in, then your going to have a problem.
Make sure you use good quality wrenches and use a tubing wrench on the line nut. If it won't come apart, then your going to get into cutting and replacing lines.
JEFFTEX1
Engine Performance problem
1995 Chevy Silverado V8 Four Wheel Drive Automatic
where is the fuel filter located?thx
JDL
  • 16,098 POSTS
Look under vehicle, driverside, mounted on the frame-rail, under seating area.
