1996 Chevrolet Silverado Repair Question
Topics covered: Brakes, Proportioning valve, Brake fluid.
Asked on March 8, 2010
1996 Chevy Silverado Brake pedal not grabbing
Brakes problem
1996 Chevy Silverado V8 Two Wheel Drive Automatic 130000 miles
My Chevy has a JB6 brake system, the pedal travels nearly to the floor befor grabbing disk/drums. I am trying to determine whether it is the brake power booster, the proportioning valve or the power boost system. The master cylinder is new, I have drained the entire system and used new brake fluid, and bled the brakes thoroughly. When I bled the brakes with the vehicle off, the brake pedal gets tight, however once the vehicle is turned on then the pedal becomes loose and has 2-3" travel, it just doesn't seem to grab immediately when depressed. Can the proportioning valve malfunction or the hydro power boost fail. I am leaning more to the power brake booster itself. Any suggestions?
