1996 Chevrolet Silverado Repair Question
Asked on April 18, 2008
1996 Chevy Silverado #2 cylinder not firing
my truck is having trouble idling, it sputters and stalls when first started. but once it runs for a few minutes it idles fine. a mechanic says it's my # 2 cylinder. i was also told it was my cats but i have replaced those already.
so my question is how labor intensive is this going to be and does it sound like a correct diagnosis.
thanks alot, jeff
Answer
Replied on April 19, 2008
Have the coolant temperature sensor/idle air control valve and throttle position sensor checked-
If it was a dead cylinder it will not idle fine you're running with 7cylinders and it will misfire and be noticeable.
