HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Ignition
Firing Order
SPONSORED LINKS
Engine firing order?
ELMER SILVA
MEMBER
1994 CHEVROLET SILVERADO
V8 two wheel drive automatic, what is the firing order of the plugs so I can install them correctly?
Monday, April 26th, 2010 AT 7:42 PM
BLUELIGHTNIN6
MECHANIC
Here is the firing order for 5.0L, 5.7L and 7.4L engines. Distributor Rotation: Clockwise
Firing Order: 1-8-4-3-6-5-7-2
SPONSORED LINKS
Monday, April 26th, 2010 AT 10:08 PM
ALEX PAZ
MEMBER
1 POST
1993 CHEVROLET SILVERADO
Engine Performance problem
1993 Chevy Silverado 6 cyl Two Wheel Drive Automatic
does anyone know what the firing order is on a 93 chevy v6 pick-up eith a 4.3l engine, I also need to know the positions on the distributor cap?
Sunday, August 9th, 2020 AT 12:20 PM (Merged)
MECHANIC
CURTIS SIMMONS
MEMBER
1 POST
1990 CHEVROLET SILVERADO
Electrical problem
1990 Chevy Silverado V8 Two Wheel Drive Automatic
I have a 305 v8. Can you tell me where #1 firing wire is on the dist. Cap. When #1d pistion is up.
JDL
MECHANIC
Welcome to the forum. Number one, up on the compression stroke.
SPONSORED LINKS
BADMOFO
MEMBER
1 POST
1989 CHEVROLET SILVERADO
1989 Chevy Silverado V8 Two Wheel Drive Automatic
I was checking spark plug wires and found one lose, I don't know if firing order is correct. Can you send a diagram of firing order on chevy 350?
DCS1998
MEMBER
1-8-4-3-6-5-7-2.
DANNY L
MECHANIC
Hello, I'm Danny.
Here is the information you requested. I've attached a picture below of the firing and cylinder order. Hope this helps and thanks for using 2CarPros.
Image (Click to make bigger)
Saturday, March 6th, 2021 AT 4:52 PM
MECHANIC
Take a look at the attachment below for the detail on the firing order and positioning of the cylinders and distributor.
Let me know if you have questions. Thanks
Saturday, March 6th, 2021 AT 4:54 PM
Please
login
or
register
to post a reply.
Related Firing Order Content
Engine Firing Order Please?
What Is The Firing Order?
Asked by
abuildtrucks
6 IMAGES
2011
CHEVROLET SILVERADO
No Ignition Spark?
99 Silverado. It Was Taking At Least Two Turns To Start My Truck. Now It Just Cranks But No Spark? Will Not Start I Was Assuming That It...
Asked by
aaron82
11 IMAGES
1999
CHEVROLET SILVERADO
What Cause Engine To Run Lean?
Engine Have A Misfire At Idle In #5 Cylinder Spark Plug Wires, Spark Plugs, Compression Or Good #5 Spark Plug Have White Carbon Build Up...
Asked by
joe1953
1 IMAGE
1996
CHEVROLET SILVERADO
Shorted Wires To Distributor
My Truck Has Had A Shorted Wire Going To The Distributor For Years, Pinched Between The Engine Block And Transmission, Just Found That Out...
Asked by
Johnny Cardin
8 IMAGES
1998
CHEVROLET SILVERADO
Interior Fusebox Ignition Fuses Have Low Voltage 5.3...
I Have Been Getting Intermittent "check 4wd" And "service Brake System" Warnings For About A Week And Over The Weekend The Fan Motor Started...
Asked by
copcarguyp71
2004
CHEVROLET SILVERADO
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement - Toyota Prius
Misfire Random Code P0300
Intermittent Misfire
Online car repair manuals
