1993 Chevrolet Silverado
Engine Performance problem
1993 Chevy Silverado V8 Two Wheel Drive Automatic 269090 miles
My vehicle continues to stall out on me when I'm about to come to a stop or stopped. So far I have changed the complete fuel sending unit/w pump, the fuel relay, the spark plugs, cleaned the idle air control to the best of my ability, and replaced vacum lines to the throttle body. After it stalls out the only way to get it restarted is to spray some starting fluid into the air cleaner assembly, because it act as though no fuel is present in the throttle body. Can any please give me a suggestion?
May 5, 2009.
Did you replace the fuel filter? Also, have you looked at the EGR valve? Make sure the valve isn't stuck or carboned.
Has the check engine light come on?
