My engine is hard to start?
NEALON86
  • 1997 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 176,896 MILES
My pickup has been acting up. Sometimes is hard to start. Backfires sometimes when trying to start. It will start eventually. Then while accelerating it sometimes backfires right before it shifts, through the exhaust.
Saturday, July 24th, 2010 AT 3:16 PM
  • 108,128 POSTS
Has the check engine light come on? it sounds like a weak fuel pump. These guides will help fix it.
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Saturday, July 24th, 2010 AT 11:12 PM
NEALON86
Thank you for the guides I found out it was the engine coolant sensor, I got new one the truck has never run better! God bless you guys.
Sunday, July 25th, 2010 AT 6:17 AM
  • 108,128 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Monday, July 26th, 2010 AT 12:17 AM
MTCHEDDAR
  • V8
  • 4WD
  • 15,200 MILES
My 97 3/4T does not like to start. I can hear the fuel pump kicking on when the ignition is turned on. I cycle the ignition (priming?) Then attempt to start. The truck cranks over and over; after a while it will sputter, then finally start. I replaced the fuel filter, did not affect anything. Fuel pressure (schraver valve) is at 30psi when ignition is turned on, and 30psi when running. Once, the psi was at 50psi when checking. Is this a fuel pump going out or a problem with the fuel pressure regulator?
Monday, January 25th, 2021 AT 12:27 PM (Merged)
RHALL77
  • 3,361 POSTS
Soounds like the fuel pump to me. Does the pressure bleed down at all when it is just sitting?
MTCHEDDAR
Nope, stays around 30 psi, increasing a couple psi when revving engine. Gonna change fuel pump tmrw. If it doesn't fix it, I will be back on here learning from anyone I can. Thanks.
Monday, January 25th, 2021 AT 12:28 PM (Merged)
RHALL77
  • 3,361 POSTS
Let me know what you find out
JSCOUT7788
  • V8
  • 121,000 MILES
Engine cranks slow and hesitates before starting
JDL
  • 16,098 POSTS
I'd make sure the battery has a full charge and the cables/wires are all clean and tight on both ends.
You can take reading across your battery posts, with everything turned off, take another reading with the engine cranking. Usually with the engine cranking, that voltage reading shouldn't drop below 9 or 10 volts.
JIGGY3
Engine Performance problem
1997 Chevy Silverado V8 Four Wheel Drive Automatic 130k miles
Have to use gas pedal to start engine sometimes when engine is warm. Starts fine when cold (even winter in MN).
JACK1959
Could be a couple of things that we have seen in our shop in the past. One is temperature sending unit is not reading correctly which could be why it starts good when it is cold. The temperature sending unit tells the computer to run lean when warm or rich when the engine is cold. After the Engine warms up and then you shut it down, then try and restart the temperature sending unit is sending info to the computer to run rich when in fact the engine is warm then makes it hard to start because of a rich fuel mixture. The other item is fuel pressure sensor or regulator not functioning correctly.
GUY JOHNSON
  • V8
  • 4WD
  • 120,000 MILES
I have try to start a few times before it starts but after its run its still a little hard to start sometimes but it will start easier after being already started and run awhile
WRENCHTECH
  • 20,757 POSTS
You need to hook up a fuel pressure gauge before starting it. This system is very pressure sensitive. You need at least 55PSI to start and it should come up to that pressure in 1 to 2 seconds.
CRAIG HAYDEN
  • 1996 CHEVROLET SILVERADO
  • 130 MILES
Truck would not start. A little ether and starts and runs until it burns off. Eventually it will start, then run normally the rest of the day. I changed the fuel filter and am hoping I don't have to drop the tank to change fuel pump.
  • 108,128 POSTS
I would recommend checking fuel pump pressure when it doesn't start. It sounds like you have a problem with the pump. Many parts stores will lend or rent a gauge to you if you need one.
TREPOD
  • 223,000 MILES
My truck is turning over very slowly, and its only a matter of time before I don't make it to work, because it's getting worse. I don't have the tools for the job, so I started with the battery. I got it covered under warranty. I replaced the battery this weekend, but I still have the same problem, so I'm wondering if it's the alternator?
I'm wondering if it's the alternator, because that was replaced about a year ago. I would say there have only been 10,000 km's since replacement.
Any way to test out an alternator cheaply?
Monday, January 25th, 2021 AT 12:29 PM (Merged)
CADIEMAN
  • 3,544 POSTS
Remove the neg. Wire on the battery if the alt. Is bad the engine will stall out.
TREPOD
Well I guess the Alternator is good, and I have a new battery. So what else could make a truck turn over slowly? It turns over like the old 425 big block I use to have. It almost stalls just before it catches. It wasn't like it before. When the winter gets here in a few weeks it won't start at all.
Solenoid/Starter?
I know the former owner had that replaced about 3 years ago.
CADIEMAN
  • 3,544 POSTS
Take it to parts store and check the cranking amps of the starter. The battery must have the proper cranking amps also. Do a complte chargeing sys. Test.3 or so years is good life for a starter. If winter coming I would fix that puppy. Ty for using 2carpros
HANGTIME120
  • V8
  • 160,000 MILES
When I go to start up my truck, mostly in the mornings, or if it sits for about a day, its really hard to start up. It takes about an average of 6 or 7 turns of the key to start. In some cases even 10 times it takes. Would the fuel pressure regulator do this? If I run it for a while, it will start fine if I try to start it in the next couple hours after I'm done without a problem. Why does it do this? Any help would be greatly appriaciated. Thanks
