Mechanics
PROPER PROCEDURE FOR BRAKE BLEEDING, S10 2WD ABS
1994 Chevrolet S-10
1994 Chevy S-10 2 wheel drive.
4 wheel ABS
6Cyl. A/C TBI 260,000 Miles
What is the proper procedure to bleed the brakes on this truck?
I have heard that you bleed like normal, and I have heard that you must use a tool to hold in the perportioning valves on the ABS unit or they will not bleed properly.
I do NOT have access to pressure bleeding equipment, and have never had good luck using any vacuum method. I will use the two man method, pump it up, bleed. Pump it up, bleed.
Please help me, having problems with brake pedal to floor after a wheel cyl leaked. Replaced, but still brakes spongey, and pedal drops to floor during ABS operation, and loss of braking force.
Note: I made a donation with my first question regarding brakes, that has yet to be answered.
Dipweed23
July 18, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
