Mechanics
CHEVY HEATER COIL
2000 Chevrolet S-10
Heater problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic 310000 miles
do I have to remove the dash to replace heater coil and I am not sure how to take it out and replace it
Ron pleasants
October 4, 2009.
I got this off line. It is the directions for replacement. I hope it helps. It is quit extensive.
1. Disconnect the negative battery cable.
2. Drain the engine cooling system.
3. Remove or disconnect the following: Heater hoses from the heater core
4. Remove the instrument panel as follows: A. Disable the air bag system.
B. Set the parking brake and block the wheels.
C. Disconnect the parking brake release cable from the parking brake lever.
D. Unfasten the screws that retain the DLC instrument panel left side sound insulator. Feed the DLC through the hole in the sound insulator.
E. Unfasten the right side sound insulator panel screws and remove the panel.
F. Unfasten the screws that attach the instrument panel left side sound insulator to the knee bolster and cowl panel.
G. Unfasten the nut that attaches the left side sound insulator to the accelerator pedal bracket.
H. Unplug the remote control door lock receiver module electrical connector.
I. Remove the door lock receiver module from the left side sound insulator. Remove the left side sound insulator.
J. Unfasten the screws that attach the instrument panel center sound insulator to the knee bolster, instrument panel, heater assembly and floor duct.
K. Remove the center sound insulator.
L. Unfasten the screws that attach the courtesy lamp to the knee bolster.
M. Unfasten the screws that attach the knee bolster to the instrument panel.
N. Disconnect the lap cooler duct from the knee bolster.
O. Unplug the lighter electrical connection and remove the knee bolster.
P. Unfasten the steering column-to-instrument panel nuts and lower the column.
Q. Unfasten the screws that attach the instrument panel accessory trim plate to the instrument panel.
R. Remove the trim plate and unplug all necessary electrical connection.
S. Remove the heater and/or air conditioning control assembly.
T. Remove the radio and the storage compartment assembly (if equipped).
U. If necessary, remove the instrument cluster.
V. Unfasten the left and right instrument panel pivot bolts and the panel lower support bolt.
W. Unfasten the speaker grilles retaining screws and remove the speaker grilles.
X. Remove the windshield defroster grille using a flat-bladed prytool. Start at one end of the grille and work your way down the grille.
Y. Unfasten the 4 instrument panel upper support screws.
Z. Tag and unplug all necessary electrical connections.
AA. Remove the instrument panel from the vehicle.
5. Remove or disconnect the following: Air inlet assembly, if equipped
Vacuum hoses
Heater assembly studs, from inside the engine compartment
Blower motor resistor
From inside the heater case assembly, the stud; the stud is located behind the blower motor resistor
Heater assembly-to-chassis screws
Heater assembly from the vehicle
Access cover screws and cover from the heater assembly
Heater core from the heater case assembly
Fig. View of the heater case assembly
Fig. View of the heater case cover
Fig. View of the heater core
To install: 1. Install or connect the following: Heater core to the heater case assembly
Access cover to the heater assembly and the cover screws
Heater assembly to the vehicle
Heater assembly-to-chassis screws and torque them to 40 inch lbs. (4.5 Nm)
The stud, working inside the heater case assembly; the stud is located behind the blower motor resistor
Heater assembly studs, working inside the engine compartment, and torque them to 17 inch lbs. (1.9 Nm)
Vacuum hoses
2. Install the instrument panel as follows: A. Rest the instrument panel on the lower pivot studs.
B. Attach the electrical connections.
C. Install but do not tighten the 4 upper instrument panel support screws.
D. Install the left and right panel pivot bolts. Tighten the bolts to 102 inch lbs. (11.5 Nm).
E. Install the panel lower support bolt. Tighten the bolt to 102 inch lbs. (11.5 Nm).
F. Tighten the upper support screws to 17 inch lbs. (1.9 Nm).
G. Install the windshield defroster grille and the speaker grilles.
H. Install the radio and storage compartment assembly (if equipped).
I. If removed, install the instrument cluster.
J. Install the heater and/or air conditioning control assembly.
K. Attach the electrical connections to the instrument panel accessory trim plate.
L. Place the trim plate in position and install its retaining screws. Tighten the screws to 17 inch lbs. (1.9 Nm).
M. Place the steering column into position and install its retaining nuts. Tighten the nuts to 22 ft. Lbs. (30 Nm).
N. Attach the lighter electrical connection and the lap cooler duct to the knee bolster.
O. Place the knee bolster into position and install its retaining screws. Tighten the Torx ® head screws to 80 inch lbs. (9 Nm) and the hex head screws to 17 inch lbs. (1.9 Nm).
P. Place the courtesy lamp in position and install its screws. Tighten the screws to 17 inch lbs. (1.9 Nm).
Q. Place the instrument panel center sound insulator in position. Install the screws that attach the center sound insulator to the knee bolster, instrument panel and the floor duct. Tighten the screws to 17 inch lbs. (1.9 Nm).
R. Install the screw that attaches the center sound insulator to the heater assembly. Tighten the screw to 13 inch lbs. (1.5 Nm).
S. Install the remote control door lock receiver module to the instrument panel left side sound insulator.
T. Attach the door lock receiver electrical connection.
U. Install the nut that attaches the left side sound insulator to the accelerator pedal bracket. Tighten the nut to 35 inch lbs. (4 Nm).
V. Install the screw that attaches the left side sound insulator to cowl panel. Tighten the screw to 13 inch lbs. (1.5 Nm).
W. Install the screws that attach the left side sound insulator to knee bolster. Tighten the screw to 17 inch lbs. (1.9 Nm).
X. Feed the DLC through the hole in the sound insulator, place the DLC in position and install its retaining screws. Tighten the screws to 21 inch lbs. (2.4 Nm).
Y. Install the right side sound insulator and tighten the screws
Z. Connect the parking brake release cable to the lever.
AA. Enable the air bag system.
3. Install the heater hoses to the heater core.
4. Refill the cooling system.
5. Connect the negative battery cable.
6. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
2. Drain the cooling system into a clean container for reuse.
3. Remove the heater hoses from the heater core.
5. Remove the air inlet assembly, if equipped.
6. Remove the vacuum hoses.
7. From inside the engine compartment, remove the heater assembly studs.
8. Remove the blower motor resistor.
9. From inside the heater case assembly, remove the stud; the stud is located behind the blower motor resistor.
10. Remove the heater assembly-to-chassis screws.
11. Remove the heater assembly from the vehicle.
12. Remove the access cover screws and cover from the heater assembly.
13. Remove the heater core from the heater case assembly.
Fig. View of the heater case assembly-Chevy/GMC S-Series Pick-up, Bravada, Sonoma and Envoy
Fig. View of the heater case cover-Chevy/GMC S-Series Pick-up, Bravada, Sonoma and Envoy
Fig. View of the heater core-Chevy/GMC S-Series Pick-up, Bravada, Sonoma and Envoy
To install: 1. Install the heater core to the heater case assembly.
2. Install the access cover to the heater assembly and the cover screws.
3. Install the heater assembly to the vehicle.
4. Install the heater assembly-to-chassis screws and torque them to 40 inch lbs. (4.5 Nm).
5. Working inside the heater case assembly, install the stud; the stud is located behind the blower motor resistor.
6. Install the blower motor resistor.
7. Working inside the engine compartment, install the heater assembly studs and torque them to 17 inch lbs. (1.9 Nm).
8. Install the vacuum hoses.
9. Install the air inlet assembly, if equipped.
10. Install the instrument panel as follows: A. Rest the instrument panel on the lower pivot studs.
11. Install the heater hoses to the heater core.
12. Refill the cooling system.
13. Connect the negative battery cable.
14. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
