Mechanics
CHEVY CRANK SENSOR CODE
1996 Chevrolet S-10
Engine Mechanical problem
1996 Chevy S-10 4 cyl Two Wheel Drive Manual 160000 miles
The check engine light came on. The scanner said it was a crank sensor. I do not know where it is located and if it a 2 or 4 prong plug? The parts dealer said the difference between the two is the 4 prong has a magnetic sensor that is longer and is inserted in near the crank?
The engine is a 2.2L
Wmjunior
August 12, 2010.
Crankshaft Position Sensor
Engine Wiring, RH Side (2.2L Engine Shown Others Similar)
http://www.2carpros.com/forum/automotive_pictures/12900_c_18.jpg
Rasmataz
Aug 12, 2010.
AD
