1994 Chevrolet S-10
Electrical problem
1994 Chevy S-10 6 cyl Two Wheel Drive Manual 211000 miles
I replaced the starter in my truck this morning and when I tried to start it, it turned over just fine but now it will not fire. I cannot hear the whine of the pump. I had no problems with fuel delivery before starter replacement. I did disconnect the battery prior to replacement. Could something have happened during reconnect? Where are the fuel relays? It will fire if I put gas in throttle body. Thanks bnail
April 28, 2009.
The fuel pump relay is under the hood. Are you getting fuel to the engine and spark?
