1999 Chevrolet Other
Just started out and it quit, dead.
No instruments, tried to re-start and not even a click.
No clock, switched to accessories, still no clock or radio.
Released the hood, and opened the door to look. There was no " key in ignition" buzzer.
No smoke, or obvious problem. I had to leave the car for about an hour, so got back in to remove my keys. I heard a faint " clunk", " clunk" about every three seconds coming from the dash.
Since I was leaving, I disconnected the Battery.
Came back in an hour, checked batt. Voltage, 12.7v.
Reconnected the batt, voltage 12.6.
Got back inside, everything normal. Started and continues to run.
I suspect a break in the source to the ignition switch.
Since it was running when it failed, I don't see an open to either the batt. Plus or ground. Wouldn't the alternator continue to provide power? Or does it share the ground with the battery?
A scan of the chip showed no faults.
Please help if you cen.
Big bear
January 28, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
