O2 sensor location
1997 CHEVROLET
LARANJOLJ
2004 Chevrolet K1500 5.3L
Where is the bank 1 sensor 2 located ?
I just want to say thanks for you information on the O2 sensor location. I had heard conflicting stories. Some said that bank 1 was the bank that the number 1 cyl. was located on. However there was only 1 sensor on that side at the manifold, then the exhaust pipe crossed over and hook up to the right bank. On the passenger side there three. 1 at the manifold, 1 before the cat., 1 after the cat. So if I understood you correctly then the sensor located at bank 1 one sensor 2 that would be the sensor on the passenger side(right bank) before the converter.
Thanks for all your help.
Mar 1, 2009 at 7:20 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,349 POSTS
Bank 1 is on the drivers side
Bank 1 Sensor 1 would be in the exhaust manifold or before the catalytic converter.
Bank 1 Sensor 2 would be the next sensor back behind the converter.
Bank 2 Sensor 1 Is the first sensor on the passengers side
Back 2 sensor 2 is the next one back on the passengers side.
Single exhaust would also be in front of the cat the exact location would depend on the design of the exhaust going into the cat, You could just have 3 sensors.
Here is a guide to help you get the sensors changed out.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Cheers, Ken
Oct 10, 2017 at 5:39 PM
KWIK93
I have a 1997 Chevrolet 1500 truck w/350 "R" code motor 2wd. The O2sensor code is P0141 Bank 1 Sensor2. Which sensor on the exhaust system is this? :?:
Oct 10, 2017 at 5:40 PM (Merged)
BACKYARDMECHANIC
  • 337 POSTS
Bank # 1 is the side of the motor which the number 1,3,5, & 7 are on and share the same exhaust manifold. I'am not familar with your particular vehicle so I can't tell you if it is the drivers side or passenger side. ( I think the odd cylinders are on the drivers side) Perhaps you will be able to determine the cylinder layout by using the layout of the igntion wires. As far as determining the senor #2, it is the senor after the catalytic convertor and in your case in bank #1. Hope this helps Backyardmechanic :)
KWIK93
thank you backyardmechanic
BACKYARDMECHANIC
  • 337 POSTS
Your welcome
TOMMART08
Other Category problem
2003 Other Chevrolet Models 4 cyl Four Wheel Drive Automatic 80.000 miles
How do i fix and locate and O2 sensor
BLACKOP555
  • 10,386 POSTS
are you looking for sensor 1 sensor 2 bank 1 or bank2?
BMRFIXIT
  • 19,053 POSTS
Hi tom
thank you again
need to have the system scanned that will help you pin point what is going on
and direct you in the right direction
as if its o2 sensor you have two O2 sensors and they both located (screwed )on the exhaust system
one before the cat converter and the other after
you need 22mm or 7/8 in wrench or a special socket to remove the sensor
good luck
let me know
STALIANO
Engine problem
2001 Other Chevrolet Models 4 cyl Two Wheel Drive Automatic 100000 miles
we went to AutoZone and did a quick check which indicated that it had to do with the oxygen sensors. What we need to know is on a 2001 Chevy Prism, how many oxygen sensors are there and where are they located. THANKS SO MUCH FOR YOUR ASSISTANCE!
MMPRINCE4000
  • 8,548 POSTS
Sorry for the late response.
There are two sensors, both in the exhaust. One located before the convertor, and one after, (term used is "upstream" and "downstream").
