Changing thermostat
VAGG1994
  • 2009 CHEVROLET MALIBU
  • 4 CYL
  • 9,000 MILES
How to bleed air out after changing thermostat in 09 chevy malibu
Tuesday, August 25th, 2015 AT 6:28 PM
HMAC300
  • 48,601 POSTS
Here is a guide to help you see what you are in for when changing the thermostat.
Cheers
Wednesday, August 26th, 2015 AT 7:36 AM
MYDLITE58
  • 8 POSTS
  • 2007 CHEVROLET MALIBU
  • 3.5L
  • V6
  • 130,123 MILES
I cannot locate the thermostat.
Thursday, October 29th, 2020 AT 9:49 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view about changing your thermostat:
I've attached pictures below of the location (circled in red) and step-by-step instructions on how to replace.Hope this helps and thanks for using 2CarPros.
Danny-
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you requested in the diagrams down below. Please go through the guides and get back to us with how everything turns out, or if you have any other automotive related questions.
Thanks,
Alex
2CarPros
MYDLITE58
  • 8 POSTS
Thank you so much. I will view the material you attached and attempt the replacement tomorrow. Thank you so much.
MYDLITE58
  • 8 POSTS
OMG! You guys are wonderful! With your help I was able to locate, remove and replace my thermostat. I did it! The information, photos and tutorial were perfect direction and made the process so much easier for me. In addition to learn how to, I also learned about tools for the car and how to improvise with what you do have on hand. Mostly importantly I learn my limitations also. (I have RA and hand strength is limited some days) I know nothing about cars and their parts or functions but I have a brain and willingness to learn. I can’t thank you enough and will always come to you before going to any mechanic again! I will tell you now and please share with all, I am a gramma trying to keep my vehicle on the road for myself and my granddaughter who uses it to get to and from school and work. I live on a very tight budget and you two have just saved us. Again thank you so very much. I will attempt to attach some photos of my work, again attempt is the key word. Should they go through they may not be in order.
DANNY L
  • 5,648 POSTS
You're welcome!
Feel free to use us anytime. Thanks again for using 2CarPros.
Danny-
AMYWAMBOLDT
  • 2005 CHEVROLET MALIBU
  • 2.2L
  • 4 CYL
  • 250,000 MILES
I have got the old thermostat out but cannot seem to get the new one in. Which way should it be facing? And how can I remove the pipe housing without removing my exhaust manifold?
  • 52,797 POSTS
Good morning,
I attached a procedure and pictures for you for this repair.
Thermostat Replacement (L61)
Removal Procedure
1. Drain the cooling system.
ImageOpen In New TabZoom/Print
2. Remove the thermostat housing to water pump feed pipe bolts.
3. Remove the thermostat housing to water pump feed pipe.
4. Remove the thermostat and retaining sleeve, noting orientation for installation.
RAYTA76
  • 111,000 MILES
I have a 2005 malibu LS 3.5 engine and im trying to locate and replace the thermostat. How do I do this?
Thank you
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
I have the location and the guide on how to change your cars engine thermostat. Here is the guide to show you what you are in for when doing the job.
You should drain and flush the system as well.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Here is what it will be like on your car I have included both 4 and 6 cylinder engines just in case.
Cheers, Ken
ARETTIG
  • 2004 CHEVROLET MALIBU
  • 2.2L
  • 4 CYL
  • 160,000 MILES
Seems to be somewhere in the back of the engine. There isn't a traditional thermostat housing
HMAC300
  • 48,601 POSTS
See pics, lube orings with coolant only and tighten bolts to 18inch lbs.
ARETTIG
Perfect. Thank you :-)
EDWARDONE
  • 2003 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 70,000 MILES
The engine light came on. I took it to a mechanic. He told me the error message says I needed a thermostat?
Friday, February 5th, 2021 AT 10:10 AM (Merged)
I am attaching the process below from the manual however, here is a video from a blazer and while it is a different engine it is pretty similar.
https://youtu.be/5w14DkYn1bU
Plus here is a guide that will help with this in more general terms.
Lastly below is the process from the manual. Let us know if you have questions. Thanks
