2000 Chevrolet Malibu
Engine Performance problem
2000 Chevy Malibu 6 cyl Front Wheel Drive Automatic 110000 miles
This is a 2000 Chevy Malibu, 3.1 engine, aprox. 110,000 miles.
In the last 3 months I have done:
- replace fuel filter
- replace fuel pump
- replace lower intake gaskets
- re-wired IAT plug
- replaced IAT sensor
I am still getting OBD codes. Most of the time I am getting " Cylinder misfire on 6" and 'Injector Malfunction on 5.&Quot; These are pretty intermitent and when I don't have them, the car runs great. When I do, it runs terrible and skips and bucks horrendously.
Sometimes, if I can get the rpms up, it smoothes out. Also, occaisonaly when it gets really bad, I get two more errors -- PO410 - Secondary Air Injection System Malfunction and PO412 - secondary air injection system switching valve a circuit malfunction.
I took it to a shop first. He said the misfire was due to a vacumn leak on the upper plenum. I then took it to the dealer. Eventually, he gave me the same diagnosis (after I told him what the first guy said) along with that I needed to change the injector on 5.
I did change the upper gaskets, and no improvement. I also checked the injector connections on 5 and made sure it was seated correctly. No improvement there.
I am skeptical on that diagnosis for two reasons. First, I couldn't find any vacumn leak when I sprayed the area with carb cleaner, and clearly replacing the gaskets didn't work. Second, I am hard pressed to believe that two unrelated problems (misfire and injector malfunction) keep happening at the exact same time over and over. I never get one without the other.
Just to remove variables, I did also replace the plug, plug wire, and swapped coils -- no improvement.
Any ideas on what could be happening here or what to try and test?
March 12, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
