1998 Chevrolet Lumina
Engine Cooling problem
1998 Chevy Lumina 6 cyl Front Wheel Drive Automatic 205000 miles
I have a new ignition switch module however you want to call it for my 98 lumina 3.1. It runs great but if you sit idle too long it will overheat & stall. You then have to let it cool off for about 15 minutes or so & get moving quick. As long as it is moving there is no problem. I was told the ignition module needs to be replaced. Where is it located? It is a flat part a little larger than a checkbook size not the actual key/switch. Is this easy to replace? I would prefer to do so myself & not pay the repairman an arm and a leg to do something if it is simple enough for me to do.
June 9, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
