Mechanics
SUBARU COOLING PROBLEM
Chevrolet Impala
I have a '93' Subaru Legacy wagon, 2.2 engine. I just had the thermostst, water pump, radiator, and head gaskets replaced. The problem is that at high way speed my temperature gauge reads normal, if I come to a stop or am idling, (after reaching full operating temperature) the needle goes up. If I put the car in neutral and step on the gas the needle comes down. I have never seen anything like this. There is some gurgling in the heater core but I'm getting plenty of heat. Any ideas?
John681
January 4, 2006.
Pull the oil filler cap. Is there a milky-brown residue on the inside of the oil cap? Kinda chocolate milkshake-ish?
If so, you need head gaskets. And yes, that would cause the problem you describe.
If not. You're still looking.
BadjerJim
Jan 6, 2006.
