Mechanics
CHEVY USED BCM
2006 Chevrolet Impala
Computer problem
2006 Chevy Impala 6 cyl Front Wheel Drive Automatic 57000 miles
MY NAME IS MARIA AND I OWN A 2006 CHEVY IMPALA AND MY BCM WENT BAD AND IT WOULDNT START SO I TOOK IT TO MY MECHANIC AND HE INSTALLED THE USED BCM FROM ANOTHER 2006 CHEVY IMPALA WITH THE SAME PART # AND IT STARTS BUT THE NOW THE RADIO DOESNT PLAY AND THE SERVICE AIRBAG AND SERVICE ENGINE LIGHT AND IM JUST WONDERING IF THE USED BCM THAT I PURCHASED CAN IT BE REPROGRAMMED TO MY CAR WITHOUT BUYING A NEW BCM.
Precious2010
June 20, 2009.
The bcm has to be set up with a tech 2, you have to set the bpp sensor and restraint id. Usually once the bcm is programmed it becomes locked and normally cannot be programed to the vin of your car, plus you have to get a bcm with the same options and engine size.I would have it scanned for the codes and see it it can even be set up.
Brian 1
Jun 20, 2009.
AD
