AC not working
2005 CHEVROLET IMPALA
95,000 MILES • 6 CYL • FWD • AUTOMATIC
SHELDONBYNUM
Good afternoon, My air conditioner in the 2005 impala start working or might i say blowing any air hot or cold. When the ac is turn all the lights on the dash board indicates power but no air is blowing. My question is , Would the air compressor stop working because the refrigerant is low and would that prevent the air from blowing when either the ac is hot or cold.
Sep 17, 2009 at 2:59 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Low AC refrig won't cause the blower motor to stop working. You need to start at the blower motor to see if it is getting power. If it is, then the motor is bad. If there is no power to it, you need to work backwards through the resister, relay, switch...
This guide should help
Sep 22, 2009 at 8:15 AM
TURBOJAY
had to get a new compressor cost me $340.00. good as new
Aug 26, 2019 at 11:30 AM
9445RYAN
  • 7 POSTS
I checked pressure and was 0 when i hooked up r134a pressure was high, with out putting any of the r134a in the system. The compressor would cycle on and off ever 3 to 5 seconds. I jumper the relay to add the r134a. The system took about 1oz and the compressor relief valve blew off the r134a since the pressure was to high. Any Ideas?
Aug 26, 2019 at 11:30 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
Iam really confused here said the pressure was zero then you said it was high when hooking the r134 up?How does that work?Also what were the high and low pressure readings at idle?Does the fan work to cool the condenser
This guide will help us
Aug 26, 2019 at 11:31 AM (Merged)
9445RYAN
  • 7 POSTS
yes the fan works, when i first checked the pressure was 0 the gage must not have been installed correctly. When i went to add the r134a the gage i had inline with the coolant read in the red (danger) area on my gage, not sure on what the actual reading was with out looking at the gage.
SATURNTECH9
  • 30,869 POSTS
Your lucky you didnt blow your hand or face off bypassing the high/low safety switch then try to charge it while the gauge was in the red.Just so know if you get enough pressure in one of those diy charge cans then can go off like a hand gernand.So please dont ever bypass a high/low safety switch ever again or any other safety device.The reason the blow off valve blew was because you bypassed the high/low safety switch and too much pressure was built.So your going to have to replace the blow off valve thats a given.But before you do that i would try to read the high and low pressures?Whats going to happening though most likely is the pressures will rise and the compressor will cycle.I need to know what the high and low pressures go up to before the ac compressor cycles?You will need a actual ac gauge set to read the pressures.Not the low side diyer low pressure gauge/charge hose.If your going to diagnose this problem yourself.Otherwise you will have to take it to a shop.
SHELDONBYNUM
To whom it may concern, the air conditioner in the chevy impala LS will stop working when you turn the air conditioner on. While looking at the compressor , and had someone to switch on an off the air conditioner. When air conditioner is engaged , i am assuming the visible piece spinning is some type of clutch on the compressor would spin when the air conditioner is place on its coldest setting and stop when the air conditioner unit is dis engage. If anyone can give me any idea to why the air conditioner is not working i would be very grateful..... Thank you
The most likely cause of an automotive air conditioner cooling problem is no refrigerant in the system. If the refrigerant has escaped past a leaky compressor or O-ring seal, leaked out of a pinhole in the evaporator or condenser, or seeped out through a leaky hose, the leak needs to be identified and repaired before the system is recharged.
On many systems, the compressor will not turn on if the refrigerant is low because the "low pressure safety switch" prevents the compressor clutch from engaging if system pressure is low. This protects the compressor from possible damage caused by a lack of lubrication.
One of the first things you should check, therefore, is compressor engagement. If the compressors magnetic clutch is not engaging when the A/C is turned on, the problem may be a blown fuse or a wiring problem. If the fuse is blown, replacing it may restore cooling temporarily. But the underlying reason for the fuse blowing in the first place needs to be identified and corrected to prevent the same thing from happening again.
If the magnetic clutch is receiving voltage but is not engaging the compressor, the clutch is defective and needs to be replaced. If there is any evidence of leakage around the compressor shaft seal, the seal should also be replaced.
If the clutch works but fails to turn the compressor (the belt may squeal in protest!), the compressor has seized and needs to be replaced.
Compressor failures are usually the result of loss of lubrication, which in turn may be due to low refrigerant in the system, a blockage (such as a plugged orifice tube which prevents refrigerant and oil from circulating to the compressor), loss of lubricant due to leaks or improper service procedures (not adding oil to the system to compensate for oil lost through leakage or component replacement), or use of the wrong type of lubricant.
R-12 systems require mineral oil while R-134a systems require various types of PAG oil or POE oil. Using mineral oil in a newer R-134a system can cause serious lubrication problems as can using the wrong grade (viscosity) of PAG oil. Always follow the vehicle or lubricant manufacturers compressor oil recommendations.
The next thing you should check when troubleshooting a no cooling problem is system pressure. For this, you need a set of A/C service gauges. Attach your service gauges to the high and low service fittings. If both the high and low side pressure gauges read low, the system is low and needs recharging. But before any refrigerant is added, check for leaks to find out where the refrigerant is going.
MMSHERIDAN
The AC in my Impala has decided to stop working just as it's warming up. Fan still works fine, and heat works well. When I go for AC all I get is air, not cold air. Any ideas what the problem could be? I'd like to have some idea so I can know if I can fix it myself or, more likely, take it to a mechanic. Thanks.
  • 31,937 POSTS
Hi there,
Often it is a case of low refrigerant due to a leak in the system, this will cause the low pressure switch to shut down the system, get a leak test done first.
Mark (mhpautos)
GTO 66
Added Freon to 35 lbs. Check air cond. fan fuse. checked controls on dash.Compressor clutch seems to be working I think. Still no cold air.
WRENCHTECH
  • 20,761 POSTS
Regardless of what that "death kit" you bought states, you cannot accurately charge and AC system by pressures. The only way it can be done is to completely evacuate the system, put it under vacuum for a period and then charge it with the exact weight prescribed for that system. Only then can you look at pressures and determine anything. At this point you don't even know if the compressor is working and that is dangerous. This is something that you should bring to an AC specialist that has the equipment to charge it properly..
D73JESTER
  • 6 POSTS
this just happened to me on Jand 12 09, I was driving back from the store turned the heater on and it was blowing cold air. Noticed the engine temp gauge was rising the vents would blow hot air then the engine would cool and this repeated till I got home when the vents no longer blew hot air. The dex cool was low i replaced it to the over flow tank ran car again and the temp continued to climb. i opened the pressure cap and the fluid wasnt over the top of the radiator cooling fins. the fans turned on and off intermintally. no fluid moved from the holding tank none visibly. no apparent leaks that can be seen with the naked eye at night on the street corner with a work light. never smelt the radiator "smell" from the vents
RHALL77
  • 3,361 POSTS
iwould suggest having the cooling system pressure checked and see where the leak is coming from. could be a water pump, intake gasket, or a head gasket
D73JESTER
  • 6 POSTS
After more research i found a few more things I am using a 15 lbs pressure caps, and there was a build up of brown sludge on it. I will be calling a mechanic in the morning lets not hope to expensive.
RHALL77
  • 3,361 POSTS
i never seen a pressure cap cause that on this type of vehicle. usually the brown sludge wont cause it either. have it pressure tested and let me know what you find
D73JESTER
  • 6 POSTS
It will hopfully be going into the shop tomorrow. I am hoping it just needs a flush and a new thermostat but since i am the least mechanically inclined i will leave in the hands of the professionals. I will keep you informed.
D73JESTER
  • 6 POSTS
well I took it to the shop and the said head gasket and water pump went bad. gave me an estimate of 1675.00 what would cause these to go bad it has less then 70000 miles on the car.
RHALL77
  • 3,361 POSTS
i have a hard time believing its both. and intake gasket and a water pump maybe. but you may have this going on. I would suggest having a second opinion done.
D73JESTER
  • 6 POSTS
I am going to go to the shop and have them show me why they suspect the head gasket and not the intake gasket? what should i ask them to get specific answers that can determine the causes of the problem? again not to mechanically inclined so the more presice the better. I may still have it looked at again by another mechanic.
RHALL77
  • 3,361 POSTS
with out being able to show you it would be hard here. have a second opinion done.
D73JESTER
  • 6 POSTS
I had it sent to another garage to look at from what I told him over the phone he is suspecting a thermostat and flush but will put a pressure test to it. I told the other garage that i was moving the car and his first words were can they do the job cheaper. well I said yes and the garage asked how much i picked a random number 1500 and the origanal garage said they could do it between 1300 and 1450. makes me want to wonder. and he said he could possibly go lower if mech takes more of a cut. So I am waiting for the 2nd garage to call me with his opinion. will keep you all informed
ISRAELH
I have a ac issue in my impala, passenger side blows cold driver side blows only hot air, heater works on both sides. Checked coolent, its good. Checked actuator, it works. What else could it be? I never had an ac problem in my car before, never filled up coolant because its always at least 90% full. The air is blowing out and everything.
HMAC300
  • 48,601 POSTS
try pulling the hvac sfuse for 60 seconds with key on then reinstalling then wait another minute and try it this sometimes resets actuators in heater unit. it could be control unit as well but you need to scan for that. but check to see if actuator is getting power this is right side similar on left.
