AC not working
2004 CHEVROLET IMPALA
202,000 MILES
CZR1760
  • 49 POSTS
This started with the fact that my wife's AC was not blowing cold air. I hooked manifild gauges and found that both high and low side pressures were low, making me think that it was low on coolant. I added leak detector dye to the system and by the time I was going to add refrigerant, the coolant was boiling back up into the resevoir. I immediately shut down the car. No coolant in the oil, no wetness on passenger side floor. After checking the thermostat (195), it did not open until after water rapidly boiling (and opened barely). I flushed the system, installed a new cap and thermostat (180). Now I filled the system and got it up to temp, and noticed that the cooling fans did not come on at all. Would not turn on with AC on or heater. All fuses checked out OK, but did not test relays, as it was getting dark. I also noticed that while on heat, the driver's side air was not very hot, neither side was cold on AC. I have also (within the last sevearl months) replaced the coolant temp sensor and rear O2 sensor, trying to get rid of engine light code (to no avail) have not had it scanned recently. I know that this is a lot of information and I'm not sure if they are all related or not, but wanted to give everything. Please help, this thing is driving me crazy.
Jul 11, 2012 at 1:18 AM
DJCL
  • CAR REPAIR CONTRIBUTOR
  • 767 POSTS
first check the under hood junction block fuses. 2 - 25a fuses fan control one and fan control 2&3. see if there is voltage on the lt blue wire and the grey @ the 2 fan motors. try adding power on them and see if they run verify good grounds on the one black wire. if you can get a scanner it would help a lot we will want to check to see if there is a ac request and fan command. than try to run the fans with the out put command. @ the ecm in the air cleaner key on try to ground the dark blue and dark green @ pins 5 and 6. this will run the fans low and ho speed.
Jul 11, 2012 at 1:36 AM
SATURNTECH9
  • 30,869 POSTS
So when you turn the ac on does the ac clutch kick in and the compressor start spining in the center of the ac clutch?Have you checked the cooling fan fuses yet?Also were the fans on when the coolant was boiling over?Do you know what temp it was boiling over at?
Jul 11, 2012 at 1:39 AM
CZR1760
  • 49 POSTS
I will put a meter on it tomorrow and verify power. I did test fuses, everything was good... did not test relays. I don't have access to a good scanner, jsut test light and voltmeter. As for the compressor, it does kick on and spins (not forzen up), but still no fan. I could not say for sure that the fans came on last night or not. The dash board temp gauge was reading over half, I would estimate 220-230, which is high for this car (usually doesn't get half way). I almost forgot.... about a month ago the car overheated due to loosing coolant, I ended up renting a hauler and towing it home. I tried to limp it, but it was not gonna happen, coolant was everywhere. One of the plastic elbows rotted away by the water pump and needed replaced. I replaced both elbows, refilled and burped the system. AC worked at that time.
Jul 11, 2012 at 1:52 AM
DJCL
  • 767 POSTS
The a/c compressor will be shut down by the ECM if the engine temp is to hi
Jul 11, 2012 at 1:58 AM
CZR1760
  • 49 POSTS
Ok, here is what I have found out so far. Both fans will power on when jumped directy to the battery. Both fans will come on if the tempature control sensor. I do not show any volts at the white wire or light blue wire, at fan plug ends. Key off, I have power on #85 for all three relays & #30 on relays, 1 & 3, 13 volts. Car running power on #85 & #30 on all three relays, 14 volts. Power on #87 on 2 & 3 & #87a, 17 volts. Also found... Key off, IF apply test light to #86 on #1 relay both fans come on low. IF apply test light to #86 on #3 relay pass side fan comes on. Clicking sounds when using test light to said leads. Burned my fingers trying to test #2 relay, nothing to report.
Jul 11, 2012 at 10:45 PM
CZR1760
  • 49 POSTS
When you speak of the BCM, I'm wondering if this may be the root of the problem, although I'm not ready to run out and buy one (ouch pricey). I know that intermitantley, the security light will come on and then the car will not start... Wait a while and bingo, it starts. I've been told that the BCM controls the pass lock as well. Maybe I'm over thinking, but just asking. I've also been told how to bypass the pass lock and just haven't done it yet.
Jul 11, 2012 at 10:52 PM
CZR1760
  • 49 POSTS
Tried to make sure that I had no air in the system, so I ran the car up to temp. Neither fan came on, coolant bubbling back out of filler neck so I decided to shut off car. Bad idea... coolant launched out of filler neck. After refilling and replacing cap I started the car and hosed off engine and got a quick whine noise (like a belt whine, but deeper tone), but went away quickly. As car ran, temp got to almost half way, no fans and coolant started boiling back into resevior and more whining this time. Whinig continued after shutting the car off. I could not identify if the whine was coming from boiling coolant of possibly something else. I hope this helps diagnose the problem and just doesn't add more confusion to an otherwise frustrating problem. Thanks.
Jul 11, 2012 at 11:52 PM
DJCL
  • 767 POSTS
its looking like the ecm is not grounding the relays . we will need a scaner to go deaped in to it.
Jul 12, 2012 at 12:11 AM
CZR1760
  • 49 POSTS
Ok, but I don't have access to a scanner anymore. Is there anyway to diagnose this porblem without the use of a scanner? I know that if I go to Auto Zone, they will just use a low end scanner that will not be albe to make any commands. Is this (ECM)an explination for the coolant backing up into the resevior?
Jul 12, 2012 at 12:23 AM
DJCL
  • 767 POSTS
If the fans don't turn on and the engine temp is gettint hot the coolant will back up.the pcm turns on low speed @ 217 f and hi speed @230 f
Jul 12, 2012 at 12:35 AM
CZR1760
  • 49 POSTS
You mentioned an ECM first and then a PCM, are you speaking of these interchangeably?
Jul 12, 2012 at 12:40 AM
DJCL
  • 767 POSTS
Same thing. Its mounted in the air cleaner box
Jul 12, 2012 at 12:43 AM
CZR1760
  • 49 POSTS
In quick research, this isn't something that I can quick swap out, dur to needed programmed at the dealer. Before I run out and drop some serious cash, do I have any other options.
Jul 12, 2012 at 12:47 AM
SATURNTECH9
  • 30,869 POSTS
Just to add this one a pcm and ecm isnt the same thing a ecm is a engine control module that runs the engine.A pcm is a powertrain control module which is a ecm and a tcm/transmission control module which control the transmission housed in the same box.If there seperate units there labeled as a ecm and tcm together there called a pcm.Also before you start replacing or thinking about replacing a computer i would be looking at the actual coolant temp with a scan tool to see if the sensor reads within 10 degrees of actual coolant temp.Best way to measure coolant temp safely is use a infared temp gun.Amazon sells obd2 scan tools that can read some live data for a little over 50.As far as the cooling fan not coming on with the ac with the pressure readings you had i wouldnt be suprised if it didnt.Could just be a matter of a bad coolant temp sensor or the wiring to it.Unless i missed the part of even checking the temp sensor or what the computer is even reading compared to actual coolant temp?
Jul 12, 2012 at 1:22 AM
BRAVESTAR1
  • 234 POSTS
Hi, I just did all this same work on my Car. It's 98 Sable, but I can tell you from experience, given I've also got one of those, that your water pump is probably broken. If it's not circulating the water, then the thermostat won't do squat. Thus your car will over heat, and kaboom!
Also check the ECT Temperature Sender. Its the one that looks like an old style Propane tank connection, not the cylinder one. Careful taking it off, as it might be brittle. This is likely why the fans won't come on.
Lastly take your car to a Valvoline or Jiffy Lube, and have them pressure test the vacuum to see if there is any leaks. For me the cause was over time, the R-134 leaks through the hoses, the system held vacuum for 20 mins, and pressure for 30, so the "free test" was worth it. Then they put in the proper coolant and oil, and the cold air made the $143 worth it.
See this question for additional details with pictures. https://www.2carpros.com/questions/2000-mercury-sable-fuse-located-fan-on
Jul 12, 2012 at 1:54 AM
CZR1760
  • 49 POSTS
Any suggestions as to a resonable priced scanner that is going to help out in this situation? Obviously something that can read live data, but do I also need something that can actually make commands? My friend who used to be a mechanic had a very high end unit, but it was worth more than the car.
Jul 12, 2012 at 2:11 PM
SATURNTECH9
  • 30,869 POSTS
A scan tool that will command the fans the only one that i know of is the tech2 which is what the gm dealers use.There is probably another one out there but it wouldnt be cheap.I worked for the gm dealers for many years and used whats called the pdt/portable diagnostic tool then we switched to the tech2 which replaced it.So iam not familar with the advanced scanners the independant shops would use.But they would be expensive lets start with what the coolant temp sensor is reading.Then we can see if its correct and then see if the computer is triggering the relay for the fans.You will also need a infared temp gun to measure engine temp right on the nipple where the upper radiator hose onto the head.I recommend a raytec one i have had mine for over 15yrs never let me down.Heres is a link to the scanner that reads some live data i was talking about.
Jul 12, 2012 at 4:26 PM
CZR1760
  • 49 POSTS
Working on so many other projects, but wanted to give an update on this one. Never got a scanner, cause I got ripped off on ebay. Anyway, I tried to add some freon and bingo.... the fans work. The air coming out of the vents is definetly cool, but not freezing. The passanger side is colder than the drivers side. Now I am hearing what sounds like water or fluid sloshing behind the dash. Could this be the heater core partially plugged? No wettness on the floor or smell of antifreeze.
Jul 28, 2012 at 3:55 PM
SATURNTECH9
  • 30,869 POSTS
The sloshing in the dash is probably water trapped in the ac box from a clogged ac drain.You will find the ac drain about the center of the firewall about half way down it will be just a hole or a rubber rubber tube.Clear it and water should come out.The reason the ac probably isnt super cold is because you have the incorrect amount of charge or the pressures are incorrect for other reasons.As far as ebay contact the ebay protection services as long as it hasnt been too long they will take care of you.I had to use them once before they were great.Also isnt your car overheating?
Jul 28, 2012 at 4:54 PM
CZR1760
  • 49 POSTS
I will try and remove the plug and let you know if water comes out. The readings on the gauges were perfect both hi and low. I didn't want to overfill the system and now I dont' remember the readings, but I know they were good. Car was overheating, but neither fan was coming on. After I added a small amount of freon, they kicked on and the car hasn't been over heating anymore. I'm getting a reading of about 62-64 out of the vent air temp 85-90 outside. Like I said, cool not freezing, but everything seems to be working now. I'm going to check the coolant level too. I've read that low coolant will make a sloshing sounds.
Jul 28, 2012 at 5:06 PM
SATURNTECH9
  • 30,869 POSTS
Never really heard low coolant make a sloshing noise inside the car but with water slooshing in the ducts yes.Also its impossible to tell when the ac is full by the pressure readings.Also the reason its not overheating is because the fans are always on with the ac on.
Jul 29, 2012 at 1:30 AM
HIDME
  • 27 POSTS
It is police package.
When push AC switch, the AC clutch engage, but stop in a few second.
I charged a can of 134a this morning.
thanks
Aug 26, 2019 at 11:33 AM (Merged)
Check the high and low pressures if okay, test the pressure switch and AC relay-compressor could be locked-up
  • 31,937 POSTS
You may have over charged the system, the A/C uses a measured amount of refregrant if over charged the high pressure switch will shut the system down, in your case there should be 2.4Lbs or 1.1kgs
HIDME
  • 27 POSTS
Thank you both for your anwsers.
I only have a simple charging kit with a gauge. should I try to release some freon? or better bring it to car shop?
thanks
Bring it to a shop that deals with auto AC
COYMAN22
  • 5 POSTS
My Ac is not blowing out cold air. We put gages on the system and it shows its has freon.Checked all fuses and relays. The two fans in engingine compartment do not come on when the ac is turned on but does when the engine gets hot. The compressor engages when turned on also. Any ideals?
If the magnetic clutch engages the compressor and still no cold air could be still low in freon or the HVAC unit
HIDME
  • 27 POSTS
Just found it works in the morning when it is cold. Does it give us any indication what part is wrong?
thanks
COYMAN22
  • 5 POSTS
The repair guy is saying it is the Expansion valve
HIDME
  • 27 POSTS
Brought it to a shop. They found out low freon, chraged and it is working now.
Take his advise
  • 31,937 POSTS
if it is low there is a leak, did they fix that if not you will be back again with the same problem.
COYMAN22
  • 5 POSTS
I am taking his advice, the only thing bad is that he is not 100% sure and its not a cheap fix, but I am putting my faith in a higher power.
COYMAN22
  • 5 POSTS
It was the compressor. And yes it was a big ouch in the wallet.
SHAKERAG09
When I turn on the heat in my 2004 Impala, it gets warm but never hot enough to warm the entire car. The higher the fan setting I use the cooler the air that is released into the car.
RENAUDTN
  • 636 POSTS
Make sure your coolant is at proper level in both the radiator (engine cool) and in your overflow tank, and bleed your cooling system properly. Check your thermostat. If it opens at a lower temperature than it should, or if it's stuck open, you won't have a lot of heat coming out of the vent. If your thermostat is stuck open by the way, your temp gauge on your dashboard should read low (or lower than usual).
If none of these fix your problem, come back and we'll look at more possible problems (blend door, etc).
Its just has to be the heart of the AC system, sorry to hear that-Good luck
BUDRED
my heater blows hot air on the passenger side ducts, but the drivers side is cold air at any setting. I have checked the coolant levels and they are fine. I'm told the thermostat is the blame but I cant really see that as the problem.
WRENCHTECH
  • 20,761 POSTS
Does your car have separate temp controls for left and right side?
